Revu eXtensions
Revu Windows eXtensions
Home   /   Revu Windows   /   Revu eXtensions
We understand there is more than one way to work.
Revu breaks new ground with Tool Chest, a revolutionary technology that keeps track of all your markups as you create them. It doesn’t stop there, though – any markup you create can be dragged into your own custom tool set for reuse. Bluebeam’s custom Profiles provide an easy way to store menus, and other display settings within Revu. Control the toolbar icons displayed within the interface, or create custom toolbars to fit your workflow. Customize stamps with Bluebeam’s Stamp Editor. Your options are endless.
Stamps
Bluebeam creates a variety of architectural and engineering stamps to meet the needs of our customers.
Installation instructions:
  • Click the Stamp you want to download and save it to the Downloads folder. This saves a Compressed .zip file.
  • Go to the Downloads folder.
  • Right-click on the compressed .zip file, click Extract All, accept the default settings and click Extract.
  • Launch Revu, click Markup > Stamp > Import Stamp, select the stamp from the new folder in the Downloads folder and click Open.
  • The next time you select the Stamp tool, this Stamp will appear in the list.
Interactive Stamps
Installation Instructions
  • Launch Revu, click Markup > Stamp > Import Stamp and open the folder with the stamp name in the Downloads folder.
  • There will be three PDFs in the folder. Select the two without “Instructions” in the name and click Open.
  • The next time you select the Stamp tool, this Stamps will appear in the list.
Profiles
Profiles provide an easy way to shape Revu’s user interface for different workflows by storing toolbars, tool sets, menus and other display settings. You can also customize the look and feel by creating and saving your own custom Profiles. Below are a few pre-defined examples that can be further tailored to your needs or used right out of the box.
Note: These Profiles are only compatible with Revu 10 and higher on Windows only.
  1. Click on the Profile you want to import to your computer and save it in the Downloads folder. A Compressed .zip file will be downloaded.
  2. Open the Downloads folder, double-click on the compressed .zip file to open it, and then double-click the Profile to import into Revu.
Dictionaries
Bluebeam allows you to import alternate Spell Check Dictionaries. Changing the Spell Check Dictionary allows you to check the spelling of text in a language other than the localized language installed with Bluebeam Revu.
Select a language in the dropdown below and you will begin to download a ZIP file containing the dictionary for that language. Then, go to Settings > Preferences from the Command bar. When the Preferences dialog box opens, choose Spelling from the menu and then click the Import button. Browse to your dictionary ZIP file and then click Open.
Note: Dictionaries are only needed on Windows with English only installations of Revu 2015 and earlier.
