Unable to calibrate a document
Summary
What to do if you're unable to calibrate your PDF drawings.
Relevant Products
Bluebeam Revu
You can't correctly calibrate a PDF drawing, or your measurements aren't accurate.
Why is this Happening?
The drawing may contain pre-existing viewports that were exported from the original CAD file as part of the PDF.
Check the Viewports section of the Measurements tab and delete any pre-existing viewports by selecting one of them, and clicking Clear All.
If you want to remove a specific viewport, select it and click the red X.
More Information
If you're using Revu 11 or above, you can find out more information about unwanted viewports and removing them in our support article called "Page Turns Blue When Doing Measurements."
One thing to consider is that there maybe times when you actually want viewports in your drawing, so to help you with this we have an FAQ explaining how you can use viewports to set multiple scales on single page.
You can also checkout FAQ section on our support page and the Revu Help Guide.
Revu 2017 & Below
Measurement
Enterprise
