Note tool
The Note tool allows for placement of a pop-up text note on a document.
Notes and comment boxes do not print by default. To print notes, select Print Pop-Ups in the Markup Preferences.
- Select the Note tool using one of the following methods:
- Go to Tools > Markup >
Note. - Click
on the Text toolbar. - Press N on the keyboard.
- Select a location on the document to place the Note. A Note icon is placed on the PDF and a pop-up window appears.
- Enter the content of the Note in the pop-up window. The pop-up window can be moved as desired.
To hide the Note pop-up window, select the X in its upper-right corner or press ESC. The Note pop-up window will appear the next time the Note icon is double-clicked.
Delete.
There are three ways to view the contents of a Note:
- Mouse over the Note icon to see a tool tip of the contents.
- Double-click the Note icon to bring up the pop-up window.
- See the Comments column in the Markups list for the Note markup.
The appearance of the Note icon placed on the document is configurable. The icon itself can be changed as well as its color and opacity.
To change the appearance of a Note icon, select the markup and select the Properties panel. Go to Window > Panels > Properties to show the Properties panel if it is hidden. Several properties will also be available on the Properties toolbar when the markup is selected.
Color: Sets the color of the Note icon and pop-up window.
Opacity: Sets the level of transparency of the Note icon.
Icon: Sets the shape of the Note icon.
