Cloud tool
The Cloud tool creates a Polygon markup with a cloud-like appearance preset. As such, the behavior of the Cloud tool is the same as the behavior of the Polygon tool.
- Select the Cloud tool using on the following methods:
- Go to Tools > Markup >
Cloud. - Select
on the Shapes toolbar. - Press C on the keyboard.
- To create a rectangular cloud, drag the shape.
- To create a polygonal cloud:
- Click to define each point of the shape. To remove the last point placed, press BACKSPACE.
Finish the cloud shape using any of the following methods:
- Select the first point again to close the shape.
- Press Enter twice or press C on the keyboard to automatically close the shape by connecting the last point placed to the first point placed.
- Double-click when placing the last point to automatically close the shape by connecting the last point placed to the first point placed.
Tips:
- Hold down SHIFT while dragging the cloud to force the shape into a square.
Delete.
Control points define where line segments meet in a multi-segment markup. Add or remove control points to adjust the shape. See Working with Control Points for more information.
Convert line segments to curves or arcs at control points to match complex shapes. See Working with Curved Markups for more information.
The appearance of the Cloud markup is configurable, including its line and fill color, hatch pattern, line width and style, and opacity.
To change the appearance of a Cloud markup, select the markup and select the Properties panel. Go to Window > Panels > Properties to show the Properties panel if it is hidden. Several properties will also be available on the Properties toolbar when the markup is selected.
Color: Sets the line color.
When Style is set to Cloud, the Size and Invert settings are also available.
Size: Sets the width of the cloud segments.
Invert: Inverts the cloud segments inward on the shape.
Size = 2.00
Size = 1.00 and Inverted
