Reorder pages
Reordering pages of a multi-page PDF in Revu is mostly a matter of simply dragging and dropping the desired page's thumbnail into the desired location. You can reorder one page at a time or several pages at the same time.
To automatically reorder the PDFs bookmarks to match, enable Automatically Reorder Bookmarks in the Document Preferences.
- Select the
Thumbnails panel. If it is hidden, go to Window > Panels >
Thumbnails or press ALT+T. - Select the thumbnail of the page you wish to move and drag it into the desired position. As you drag, a blue line appears to indicate where the page will be inserted. When you release the page, it will be inserted in the indicated position and the pages of the PDF will be automatically renumbered.
- Select the
Thumbnails or press ALT+T. - SHIFT-select (for pages in a range) or CTRL-select (for pages not in a range) and drag the selected pages into the desired position. As you drag, a blue line appears to indicate where the pages will be inserted. When you release the pages, they will be inserted in the indicated position and the pages of the PDF will be automatically renumbered. The pages that you have moved will retain their relative position to one another.
For example, if you moved pages 2, 5, 9, and 18 of a 20-page PDF to the end of the PDF, they would become pages 17, 18, 19, and 20 respectively.
