Export documents
PDFs can be exported out of Revu into different file types, depending on your need. The most popular image file types are supported to convert each page of a PDF into a separate image, or PDFs can be exported as text, HTML, or one of the common Microsoft Office files (Word, Excel, or PowerPoint). In the event that a scanned PDF is being exported as a Microsoft Office file, Revu will automatically perform a text recovery procedure in order to convert the PDF into the new format as faithfully as possible.
You can export only a selected region of a page as an Excel file. Because it is being exported into an Office file format, the same text recovery process is used, letting you turn scanned tables in drawings into functioning Excel tables.
See Creating a PDF/A-1b Archive for more information.
When you export a document as an image file, each page is converted into an image file of the selected file type.
- Open the document you want to export. The active PDF is automatically the one that is exported.
- Go to File >
Export and select the image file type you wish to export as. The following image file types are supported:- TIFF
- JPEG
- PNG
- GIF
- BMP
- Navigate to the folder where you want to save the file and select Save.
The files will be automatically numbered for you as they are saved. The suffix used is determined by your Import/Export Preferences, the default suffix being "Page" followed by a three-digit number. So if the file name in the Save As dialog is MyFile.png and the default suffix is used, the first page will be automatically named MyFile Page 001.png, the second will be MyFile Page 002.png, and so on.
PDFs can be exported as a simple text file (.txt), a Rich Text Format (.rtf), or as Hypertext Markup Language (.htm). Each of these formats is functional but with some limitations. Simple text files, for example, will only contain unformatted text from the original PDF; RTF files will only contain markups that have been flattened, and even then some properties are not carried over (for example, opacity); and HTML might have trouble translating complex PDFs.
- Go to File >
Export and select from the desired option:- Text will produce a simple text document (.txt).
- RTF will produce a Rich Text Format document (.rtf).
- HTML will produce a Hypertext Markup Language file (.htm).
PDFs can be exported into Microsoft Office files, include Word, Excel, and PowerPoint. The export function supports scanned documents by performing text recovery before converting it, resulting in documents you can edit.
Go to File >
Export > desired Office format > Entire Document.The following Office file types are supported:
- Word
- Excel
- PowerPoint
You can export specific page regions into Microsoft Office files, such as an Excel spreadsheet. This can be particularly useful when you want to capture a table from a drawing and turn it into a functional Excel table. The export function in Revu supports scanned documents by performing text recovery before converting it, resulting in documents you can edit.
- Go to File >
Export > desired Office format > Page Region. - Drag a rectangle over the page region to export. Only text within the rectangle will be exported. When you release the mouse, the Save As dialog appears.
