Layers panel
The
Layers panel provides quick access to layers, layer configurations, and tools for creating and deleting layers.
The image below shows an example of the Layers panel of a layered PDF:
Layers with child layers will have a toggle triangle to the left of their names. Click this triangle to expand or collapse the list of child layers.
Go to Window > Panels >To show or hide a layer, select the box to the left of the layer's name to toggle its visibility. A layer with an
eye icon in the box is visible and a layer with an empty box is hidden.
To show or hide a parent layer and all its child layers at the same time, right-click the parent layer and select Show Layer. This toggles the show/hide setting of both the parent layer and all child layers.
To show only one layer, right-click the layer name and select Isolate. The selected layer and its children will be shown and all other layers will be hidden.
See Using Layer Visibility for more information.
Drag a layer to move it to a new location in the layers list. A small triangle will appear to show where the layer will be located when you release it. Move the cursor to the right to make the layer a child of the layer above the cursor.
Layers menu:
Reset Layers: Resets the display of layers to the selected configuration.
Show Print Layers: Sets to visible only the layers that have Print Usage set to On in the layer properties.
Show Export Layers: Sets to visible only the layers that have Export Usage set to On in the layer properties.
Show All Layers: Sets all layers to visible.
Show Layers on Page Only: Hides the layer names that are not on the current page.
Show Layers Alphabetically: Sorts the top level layers alphabetically.
Dial: This menu only appears when Revu detects the presence of a Surface Dial. Select a mode for the Surface Dial that determines how layers are shown as the Surface Dial is rotated:
- Isolate: Shows only the current layer.
- Build: Shows each layer scrolled through in progressing order.
- Select: Scrolls through layers without changing the view. Press the Surface Dial to select the current layer, either hiding or showing it depending on its current state.
Add New Layer: Adds a new, blank layer to the PDF. The location of the new layer depends on the option selected from the menu.
- Add Before: Creates a new layer before the selected layer. If no layer is selected, the new layer is added to the top of the layers list.
- Add After: Creates a new layer after the selected layer (default). If no layer is selected, the new layer is added to the bottom of the layers list.
- Add Child: Creates a new layer as a child of the selected layer. If no layer is selected, this option is not available.
Add Layer from Page: Adds a layer to the PDF from the content of a source PDF. The location of the new layer depends on the option selected from the menu.
See Adding Layers to a PDF: Creating or Importing Layers from a PDF for more information.
Configuration list: Shows the current configuration. Select a configuration from the dropdown menu to switch to it.
Save Configuration menu
Save Configuration: Saves the current visibility settings as the current configuration shown in the Configuration list.
New Configuration: Saves the current visibility settings to a new configuration.
Delete Configuration: Deletes the selected configuration.
The following options are available in the context menu of a selected layer (right-click a layer to reveal this menu):
Show Layer: Toggles to display or hide current layer or layers.
Isolate: Displays this layer and its children, and hide all other layers.
Show All: Displays all layers.
Markup Layer: Sets the selected layer as the Markup Layer. New markups will be created on this layer. The
markup layer icon appears after the layer name.
Add Layer from Page: Creates a new layer from another PDF file. Works exactly as the
Add Layer from Page button.
Add New Layer: Creates a blank layer. Works exactly as the
Add Layer button.
New Layer Group: Creates an item in the layer list that is not a layer. This is primarily an organizational tool. Layer groups are recognizable by the fact that they do not have a toggle box to the left of their names.
Rename: Changes the name of the layer.
Delete: Deletes the selected layer.
Export Layer to Page: Exports the selected layer or layers to a PDF. If a layer has children, they are also exported. If a selected layer is not currently displayed, the layer will export without the content.
Import Layer from Page: Imports a PDF content and its layers. The Import Layer dialog appears.
Flatten Markups: Flatten all markups to the selected layer. The Flatten Markups dialog appears with Assign Layer and the selected layer preselected. The default is that the markups will be flattened to their existing layer.
Unflatten Markups: Unflattens markups that have previously been flattened.
Layer Properties: Opens the Layer Properties dialog to control the settings of a layer.
Title: The name of the layer. Does not appear if multiple layers were selected.
Default State: Sets the default display state when the PDF is opened.
Locked: The title and default state cannot be changed from the layers list while this is checked. A
will appear before the layer name when it is locked. View: Sets whether a layer will be shown (On) or hidden (Off).
Print: Sets whether a layer will be included in when the PDF is printed.
Export: Sets whether a layer will be included in an export when using Export Layer to Page.
Zoom: Sets whether the contents of a layer are always visible or are only visible when the user zooms in (or out) within a defined range. To enable, select On when in range and then define a zoom range. The contents of this layer will only appear when the display zoom is within this range.
