Create and edit the 3D Model window
In Revu, all 3D content appears inside a 3D Model Window. You can easily move or resize this window using the 3D Editor.
- Select Edit > PDF Content >
Add & Edit 3D Content. - Click and drag to draw a rectangle where you want the 3D model.
In the Open dialog, find and select your 3D file (*.u3d or .ifc), then click Open.
- In the Add 3D Content dialog, choose a view from the Add Views dropdown.
- Choose your Default Display Settings. You can change these later if needed.
- Select OK.
The following procedures describe moving, resizing, and deleting 3D model windows. For other interactions, see Interacting with 3D PDFs.
- Go to Edit > PDF Content > Add & Edit 3D Content.
Select the 3D model window.
- Drag it to the new location.
- Select the 3D model window.
- Drag any yellow control point to adjust the size.
- Right-click the 3D model window.
- Select Delete.
When you finish, select Esc or switch to another tool.
