Change default folder location
Once you setup a SharePoint document management system (DMS), this becomes your default location for saving and opening documents in Revu. If you would like to change the default open/save location back to the Local Disk, follow the steps below:
After completing these steps, you will only be able to open and save files to SharePoint by utilizing the Document Management toolbar.
- Open Revu and go to Revu > Preferences (Ctrl+K).
- Under Interface, select the FileAccess tab.
- Make sure Open and save files to DMS from toolbar only is selected.
- Select OK.
Preferences
