Create black and white PDFs from AutoCAD
AutoCAD plot style tables (".ctb" and ".stb" files) define the line color and line weight when PDFs are created from AutoCAD drawings. Use the following instructions to create a black and white PDF.
The Bluebeam plugin for AutoCAD is supported by Revu 21 (with a Core, Complete, or Max plan) and by Revu CAD and eXtreme. If you have Revu 20 with a Basics plan, use the Bluebeam PDF printer.
Using the settings in the AutoCAD page setup through the
Create PDF button of the plugin:
- Open the drawing in AutoCAD.
- Select the Layout tab you want to configure.
- Click File > Page Setup Manager > Modify.
- Select monochrome.ctb in the Plot style table list.
- Check the Plot with plot styles check box, and click OK.
- Click
Create File to create the PDF file.
Using the Custom PDF Page Setup through the
Change Settings button of the plugin:
- Click
Change Settings, then the Page Setup tab. - Select Custom or Global in the Page Setup list.
- Select monochrome.ctb in the Plot style table list, and then check the Plot with Plot Styles check box.
- Click Create File to create the PDF file.
Using the Bluebeam PDF printer:
- Open the drawing in AutoCAD, AutoCAD LT or Design Review.
- Select the Layout tab you want to plot.
- Click File > Plot, or File > Print > Plot.
- Select Bluebeam PDF in the Printer/plotter Name list.
- Select monochrome or Grayscale in the Plot style table list.
- Check the Plot with plot styles check box, and then click OK.
Refer to your AutoCAD documentation for assistance on creating plot style tables. You can use the standard "monochrome" plot style as a template to create a customized file for your company.
AutoCAD plot style tables (".ctb" and ".stb" files) define the line color and line weight when PDFs are created from AutoCAD drawings. Use the following instructions to create a black and white PDF. The plugin for AutoCAD is supported by Revu CAD and eXtreme®. Use the Bluebeam PDF printer if you have Revu Standard.
Integrations & Plugins
