Show multiple measurement values for a markup
Revu can show multiple measurement values within one measurement markup, which eliminates redundancy when performing takeoffs. Instead of taking separate area and perimeter measurements, you can take an area measurement that displays a perimeter measurement as well.
- As with any measurement, be sure to calibrate the document first.
- Go to Tools > Measure >
Area (Shift+Alt+A).
- Take your measurement.If a scale has not been set on your document, a window appears allowing you to set your scale.
- Select your measurement, then choose
Show Caption from the dropdown in the Properties toolbar. Select the measurement values you want to display.
The measurement caption is displayed over the markup. The caption can be moved by holding the Shift key and dragging the caption to a more visible location.
Measurements
Interface
