Perform multiple jobs with the Bluebeam Stapler
You can use the Bluebeam Stapler to convert multiple files at the same time in bundles known as "jobs". You can add multiple jobs to the Stapler and convert them at once.
The output file is displayed in the first row, indicating the filename that will be created, the output location, and creation date. Before the PDF filename is an icon which can be used to expand and collapse the list of source files included. The order of the files in the job is important, as this is order the pages will appear in the resulting PDF.
Select one or more source files in the list and click the up, down and sort buttons to reorder source documents within each job, or click and drag them to a new order. Delete one or more source documents from a job by click the delete button. Add additional files to convert by dragging from a Windows Explorer folder into the Stapler.
Where the source file is dragged will determine if a new conversion job will get created or if the source file will get appended to a PDF job. If a file is dragged onto an existing job, the Stapler will attempt to insert the file in that location. When a new job is created, the Stapler window will display a second job.
To change the parameters of a job, select the job name, and click Configure.
More Information
Overview of the Bluebeam Stapler
How to configure jobs in the Bluebeam Stapler
Integrations & Plugins
