Install the SharePoint integration app
- Revu 20.1 and above
Bluebeam offers an integration for SharePoint that allows you to open PDFs in Revu directly from SharePoint. To use the integration, your SharePoint administrator must upload the integration package to your organization's SharePoint app catalog.
Client Requirements
To use the SharePoint integration, you must install or update to Revu 20.1 or above. The integration is supported in all modern browsers (for example, Chrome, Firefox, and Edge).
The Revu installer deploys a custom protocol handler in the client registry, which is responsible for forwarding the request from the browser to Revu. If this registry key becomes corrupted, uninstalling and reinstalling Revu will recreate the handler.
Download the app package files based on your version of SharePoint below:
For detailed installation instructions from Microsoft, select your version of SharePoint below:
- SharePoint Online in Microsoft 365
- SharePoint Server 2019 (Revu 21)
- SharePoint 2013, 2016, 2019 (Revu 20)
Post-installation
After your SharePoint administrator installs the integration, selecting any PDF in the Documents list will display an Open in Revu button on the Command Bar. The same option will be available in the context menu when right-clicking a PDF.
Since the app package is separate from Revu, you won't need to update SharePoint each time a new version of Revu is deployed unless a new functionality is added in the newer version of the integration.
If you want to navigate SharePoint from within Revu, see Add SharePoint as a document management system in Revu.
Installation
Integration
Plugins
