Revu Installation Guide
This guide will help you install Revu on a single computer. If you're an IT Administrator attempting to deploy Revu across multiple computers, see Revu 21 IT Admin Resources.
Revu 21 automatically installs in Read-only mode if you don't have an active Bluebeam subscription plan. To register for a free trial of our most comprehensive Bluebeam Plan, click here.
Pre-installation checklist
- Ensure compatibility and update Windows: Use the Bluebeam Revu Compatibility Chart to confirm that your system is compatible with Revu. Check your Windows updates and complete any pending reboots, as failure to do so may cause issues with the .NET Framework for Revu 21 installations.
- Save your work: Close any running programs, since the system may need to restart before the installation is complete. If you're a Studio user, check in all Project files and ensure pending Session items have been uploaded to avoid potential data conflicts between versions. Click here for more information on reconciling changes.
Install Revu
To download the Revu 21 installer, go to the Download Center and select Download for Desktop.
- Open the .exe file you downloaded.
- In the installer, select the desired language and click Next.
- If you're installing Revu for the first time, follow the prompts in the installer.
- If you already have Revu 2016 or later installed, the installer will prompt you to select one of the following installation options:
- Select Upgrade if you want to update your existing software to the latest version.
- Select Side-by-Side if you want to evaluate a new version of Revu, and you want to keep both instances of Revu on your computer.
You must have a version of Revu that is two generations prior to the version you install. Otherwise, the older version of Revu will be uninstalled.
- Select Install.
- Select Finish.
When the installation is complete, you can sign in to Revu 21 with your Bluebeam ID (BBID).
Start Using Bluebeam
Bluebeam University
Find onboarding courses for Architects, Engineers, Estimators, Project Managers, and other professionals that take 30 minutes or less.
If you're unable to sign in to Revu 21, click here for steps to troubleshoot.
If an issue persists in Revu 21, contact us for further installation and registration support.
