Reinstall Revu
If you need to reinstall Revu for any reason, such as a computer crash or a new operating system, the first thing you should do is find the license certificate that was sent to the license owner's email from registration@bluebeamops.com. You'll need the serial and product key to complete the registration.
If you're unable to find your license information, see Find your Revu product key.
Reinstall the Software
Please refer to the Bluebeam Revu Compatibility Chart to confirm that the version of Revu you want to install is compatible with the operating system and associated software on your machine. Make sure you only download and install the edition and version number listed on your license certificate.
  1. Reinstall Revu by downloading the version and edition listed in your license certificate.
  2. Save the installation file to your hard drive, and then double-click it to install the software. See the Revu Installation Guide if you need any assistance installing the software.
  3. Register the software using the serial number and product key listed in your license certificate.
If you cannot unregister your previous device
If you receive an error stating that the number of authorized installations has been exceeded, or, if your computer has crashed, been re-imaged or reformatted—thus preventing you from unregistering—you'll need to contact us to have the seat released. Please submit a support ticket by following the steps below, as we will not be able to handle this request over the phone.
The ability to release and reassign seats between computers using our legacy licensing system is no longer available. As of the dates listed below, legacy versions have been removed from our support site and are no longer available for download. If you need a copy for archival, please download it before the date listed below or contact us afterward for a direct download link along with a copy of your original license certificate. After these dates, you'll no longer be able to reassign or transfer legacy licenses between computers.
  • Revu 2015 and earlier: May 12, 2026
  • Revu 2016–2019: June 23, 2026
  • Revu 20: July 31, 2026
Licenses already activated will continue to work on the computers they are installed on. As of the dates above, those licenses cannot be transferred to a new or replacement computer. If you replace or upgrade hardware, you'll need a Bluebeam subscription plan to continue using Revu.
For more information, see Bluebeam End of Life (EOL) Support.
  1. Go to the Contact page.
  2. Enter your name and email.
    The email address you provide must correspond to an email address listed as a contact for your license.
  3. Under Comments, copy the template below and paste it under Describe Your Issue. Be sure to include your computer name, serial number, and a brief explanation of why you need the seat released.
    Hi,
    I'd like to request to have my seat released for computer {computer name} under serial number {your serial number here}.
    I need this seat released for the following reason(s):
    {brief explanation of why you need the seat released}.
    Thanks! {Your Name}
Find your computer name:
See the following Microsoft support page for locating your computer name.
Find your Revu serial number:
Go to Revu > About. The serial number will be listed under the version number.
Use Revu in trial mode
While your issue is being resolved, you can select Use as Trial when prompted to register your software. This will give you access to all features in Revu 20 for 30 days. Once the trial ends, you can continue using Revu, but only in View mode.
Setup
Installation
Licensing & Registration
Learn what to do if your computer crashed and you need to reinstall Revu. Read this step-by-step article to quickly reinstall and register Revu.
