Whitelist Bluebeam solutions by domains or IP addresses
- Bluebeam on web and mobile
If you're an IT admin who needs to whitelist Revu, Studio, and/or Bluebeam on web and mobile for users, use the information below to access regions and services, domains and wildcards, and steps for how to obtain IP ranges from AWS.
Bluebeam AWS Regions & Services
- Region: us-east-1
- Service: AMAZON
- Service: CLOUDFRONT IPS
- Region: ca-central-1
- Service: AMAZON
- Region: eu-west-2
- Service: AMAZON
- Region: ap-southeast-2
- Service: AMAZON
- Region: eu-central-1
- Service: AMAZON
- Region: eu-north-1
- Service: AMAZON
Whitelist by domains or wildcards
- studio.bluebeam.com
- gds.bluebeam.com
- studiorealtime.bluebeam.com
- internalapi.bluebeam.com
- portal.bluebeam.com
- activation.bluebeam.com (for registering Revu)
- login.bluebeam.com
- login.microsoftonline.com (validation token for licensing Revu 20, not part of AWS)
- accounts.bluebeam.com
- identitygateway.bluebeam.com
- okta.bluebeam.com
- org-admin.bluebeam.com
- app.bluebeam.com
- signin.bluebeam.com (for sign in/login authentication)
- lagapi.bluebeam.com (for authorizing Revu 21)
- revusyncbff.bluebeam.com (for syncing Revu 21 tool sets in Bluebeam on web and mobile)
- updatesservice-p-xx-ue1.bluebeam.com (the update service for all versions and all regions)
- lag.bluebeam.com
- sync.bluebeam.com
- alpha-api.gocanvas.com
- api.gocanvas.com
Wildcards
If you're able to use wildcards *, these are the only domains you'll need to whitelist:
- *.bluebeam.com:443
- *.amazonaws.com:443
- studio.bluebeam.ca
- internalapi.bluebeam.ca
- studiorealtime.bluebeam.ca
- app.bluebeam.ca
- storage.bluebeam.ca
- notifications-api.bluebeam.ca
- files.bluebeam.ca
- studioapi.bluebeam.ca
- searchgateway.bluebeam.ca
- firmus-gateway.bluebeam.ca
- prx-gateway.bluebeam.ca
- prx-gateway-02.bluebeam.ca
- dwgai-api.bluebeam.ca
- stn-sds-svc.bluebeam.ca
- apptiles.bluebeam.ca
- rover-promo.bluebeam.ca
- rover-promo-2.bluebeam.ca
- q-api.bluebeam.ca
- tsvc.bluebeam.ca
- storage-signaling.bluebeam.ca
- studio-webhooks.bluebeam.ca
- studio-ca.bluebeam.ca
Wildcards
- *.bluebeam.ca:443
- bluebeamstudio.co.uk
- login.bluebeamstudio.co.uk
- internalapi.bluebeamstudio.co.uk
- activation.bluebeamstudio.co.uk (for registering Revu)
- studiorealtime.bluebeamstudio.co.uk
- accounts.bluebeamstudio.co.uk
- signin.bluebeamstudio.co.uk
- lagapi.bluebeamstudio.co.uk
- revusyncbff.bluebeamstudio.co.uk
- okta.bluebeamstudio.co.uk
- app.bluebeam.co.uk
- lag.bluebeam.co.uk
- revusyncbff.bluebeam.co.uk
- sync.bluebeam.co.uk
- gds.bluebeam.com
Wildcards
- *.bluebeamstudio.co.uk:443
- *.bluebeam.co.uk:443
- bluebeamstudio.com.au
- studiorealtime.bluebeamstudio.com.au
- internalapi.bluebeamstudio.com.au
- activation.bluebeamstudio.com.au (for registering Revu)
- login.bluebeamstudio.com.au
- accounts.bluebeamstudio.com.au
- signin.bluebeamstudio.com.au
- lagapi.bluebeamstudio.com.au
- revusyncbff.bluebeamstudio.com.au
- okta.bluebeamstudio.com.au
- app.bluebeam.com.au
- revusyncbff.bluebeam.com.au
- lag.bluebeam.com.au
- sync.bluebeam.com.au
- gds.bluebeam.com
au.gocanvas.com
au-api.gocanvas.com
Wildcards
- *.bluebeamstudio.com.au:443
- *bluebeam.com.au:443
- bluebeamstudio.de
- studiorealtime.bluebeamstudio.de
- internalapi.bluebeamstudio.de
- activation.bluebeamstudio.de (for registering Revu)
- login.bluebeamstudio.de
- accounts.bluebeamstudio.de
- signin.bluebeamstudio.de
- lagapi.bluebeamstudio.de
- revusyncbff.bluebeamstudio.de
- okta.bluebeamstudio.de
- app.bluebeam.de
- lag.bluebeam.de
- revusyncbff.bluebeam.de
- sync.bluebeam.de
- gds.bluebeam.com
Wildcards
- *.bluebeamstudio.de:443
- *.bluebeam.de:443
- bluebeamstudio.se
- studiorealtime.bluebeamstudio.se
- internalapi.bluebeamstudio.se
- activation.bluebeamstudio.se (for registering Revu)
- login.bluebeamstudio.se
- accounts.bluebeamstudio.se
- signin.bluebeamstudio.se
- lagapi.bluebeamstudio.se
- revusyncbff.bluebeamstudio.se
- okta.bluebeamstudio.se
- app.bluebeam.se
- lag.bluebeam.se
- revusyncbff.bluebeam.se
- sync.bluebeam.se
- gds.bluebeam.com
Wildcards
- *.bluebeamstudio.se:443
- *.bluebeam.se:443
gds.bluebeam.com:443
login.okta.com:443
LD.bluebeam.com:443
*.oktacdn.com:443
Required for Smart Overlay and Smart Review:
firmus.ninja:443
pdf.firmus.ninja:443
*.s3.eu-west-2.amazonaws.com:443
Whitelist by IP addresses
In each region that hosts Bluebeam solutions, the IP ranges are dynamic, and AWS updates their IP Range JSON file frequently. On their website, Amazon states the following best practices for retrieving AWS IP Ranges:
Amazon Web Services (AWS) publishes its current IP address ranges in JSON format. To view the current ranges, download the .json file. To maintain history, save successive versions of the .json file on your system. To determine whether there have been changes since the last time that you saved the file, check the publication time in the current file and compare it to the publication time in the last file that you saved.
- Download and install AWS PowerShell.
- Run the following command to return all the IPs in your geographic location and display the results in the PowerShell console.
Copy
(@(Get-AWSPublicIpAddressRange -Region us-east-1) | ? { $.IpAddressFormat -eq 'Ipv4'-and $.Service -eq 'AMAZON' }).IpPrefix - Run the following command to store the results into a .txt file.
Copy
(@(Get-AWSPublicIpAddressRange -Region us-east-1) | ? { $.IpAddressFormat -eq 'Ipv4'-and $.Service -eq 'AMAZON' }).IpPrefix > C:\Users\\Downloads\AMAZON.txt
Additional Resources
- IP Range JSON File
- IP Range Documentation
- PowerShell Cmdlet
- AWS Blog
- AWS Public IP Address Changes via Amazon SNS
If you use the Sender Policy Framework (SPF) Record, you must add the IP addresses for your region to the list of authorized senders, so users can validate their Bluebeam ID (BBID) accounts and receive automated emails from Bluebeam.
- US: 54.240.43.6, 54.240.43.7
- CA: 54.240.81.145, 54.240.81.144
- DE: 76.223.184.4, 76.223.184.48
- SE: 23.251.241.6, 23.251.241.7
- AU: 69.169.234.170, 69.169.234.171
- UK: 23.249.219.49, 23.249.219.50
