Bluebeam add-in for Outlook is not available
New Outlook for Windows doesn't support COM add-ins, which includes the Bluebeam plugin for Outlook. This means that the Bluebeam plugin will not appear in the Ribbon within new Outlook. To learn more about the reason behind this change, see Microsoft's documentation.
Solutions
Use the Bluebeam Printer
Use the Bluebeam PDF printer to save any printable document as a PDF.
- From any program that can print to a printer, open a page to save as a PDF.
- Open the Print menu, usually File > Print.
- In the Printer dropdown, select Bluebeam PDF as your printer.
- Adjust the printing parameters as if you were physically printing the document.
- Select Print.
Use the default Microsoft Print to PDF
Similar to selecting the Bluebeam PDF printer, Outlook allows you to print a message as a PDF when you select Microsoft Print to PDF in the Printer dropdown.
Integrations & Plugins
The Bluebeam plugin for Outlook is not available in new Outlook for Windows. Here are some alternative ways to print to PDF.
