AutoCAD PDFs default to letter page dimensions
- Revu 21 & Below
For Revu 21, Bluebeam plugins for CAD software are exclusive to Core, Complete, and Max plans. For Revu 20, Bluebeam plugins are exclusive to CAD and eXtreme edition licenses.
When you create a PDF using the Bluebeam plugin for AutoCAD, the page dimensions are changed to Letter.
Cause
This generally occurs when the selected printer doesn't have a page size that matches the page setup information stored in the DWG file. In AutoCAD, the process of using the Bluebeam plugin is exactly the same as a user changing the page setup information.
To fix the page setup, revert the page back to its original dimensions after creating the PDF in AutoCAD. To do this, go to Edit > Undo Page Setup.
Integrations & Plugins
Follow these instructions if your PDFs from AutoCAD are defaulting to Letter page dimensions.
