Revu creates a blank PDF from AutoCAD
A blank page is created from the Bluebeam plugin for AutoCAD or the PDF printer.
The active page size is smaller than the desired printable area. Configure print settings in AutoCAD or the Bluebeam plugin to include the desired drawing area.
Change the Page setup in AutoCAD:
- In AutoCAD, go to the Output tab and select Plot (Ctrl+P).
- In the Paper Size dropdown, choose a paper size appropriate for your drawing area.
- Select OK.
Use the Bluebeam plugin to override the AutoCAD Page setup:
- From the Output tab, select Change Settings.
- Select the Page Setup tab.
- In the Page Setup dropdown, select Custom.
- Select OK.
Integrations & Plugins
