Editing a flattened PDF prevents markups from being unflattened
Editing a flattened PDF prevents all markups from being unflattened.
Cause
Markups cannot be unflattened because editing a PDF's page content changes the flattened markups. When flattening markups in Revu, please be aware that the following commands, if executed on a page containing flattened markups, will prevent all markups on the page from being unflattened:
Edit Text
Search and Replace
Erase Content
Cut Content
Reduce File Size
Apply Redactions
Color Processing
If you're a Revu 21 user, you must have a Core or Complete subscription to accessColor Processing. To learn more about Revu 21 subscription features, click here.
- Repair PDF
If you intend to use these commands to edit a PDF that contains flattened markups, be sure to unflatten your markups prior to executing the commands. You can then re-flatten your markups afterwards. This will keep your markups recoverable.
To learn more about flattening / unflattening markups, see Flattening Markups in the Revu Help Guide.
Markup
Editing Documents
