Error: "File is locked by another user. Would you like to open a read-only copy of this file?"
When attempting to open a PDF file, an error says:
Error Opening File: "File is locked by another user. Would you like to open a read-only copy of this file?"
Cause
This happens when Windows doesn't have a built-in PDF viewer for displaying files in the preview pane. Instead, Windows uses a third-party PDF viewer to mark the file as locked, or in use.
Solutions
Change the default PDF viewer
Revu includes a PDF previewer for Windows File Explorer that doesn't mark files as in use. The PDF previewer is activated when Revu is set as the default PDF viewer in Windows. To set Revu as the default PDF viewer, follow Microsoft's instructions.
Edit your Revu preferences
You can also edit your Revu Preferences:
- Go to Revu > Preferences.
- Select General from the left-hand menu.
- Select the Document tab.
- Clear the checkbox for Prompt user if file is locked.
- Select OK.
Files stored on a server
If this error appears when opening a file stored on a server, it's possible that another user has the same document open. Some network processes, such as backup or synchronization utilities, may also mark files as in use.
Error Message
