Error: "OCR module failed - Failed to replace document pages"
When trying to run OCR, Revu displays the OCR Module report dialog with the following errors:
- OCR module failed
Cause
These errors occur in either of the following conditions:
- The PDF is too large or has too many pages.
- The Windows user name contains special characters (such as @ # * _ ^ & +).
Solution 1: The PDF is too large or has too many pages
- Select Document > OCR.
- In the OCR dialog, select Page Chunk Size and set the field value to "1".
- Click Save to run OCR.
Solution 2: The Windows user name contains special characters
Determine whether the Windows user name contains a special character. If so, create a new profile that contains no special characters. This change will allow the OCR module to run successfully.
