Error: "The media name selected could not be found on the HDI postscript printer PC3 file"
The following error message appears when creating a PDF from AutoCAD:
"The media name selected could not be found on the HDI Postscript printer PC3 file."
To resolve the issue, rebuild the AutoCAD Pages Sizes using the Bluebeam Administrator and reinstall the Bluebeam PDF printer:
- Exit AutoCAD, if it's open.
- In Revu, go to Revu > Administrator .
- Select the AutoCAD Page Sizes tab.
- Select Clear and then Rebuild.
- Select the Printer tab.
- Select the Reinstall Printer button, if the printer isn't installed.
- Select the Plugins tab.
- Clear the AutoCAD checkbox and select Apply.
- Select the AutoCAD box and select OK.
Error Message
Printing
The following error message appears when creating a PDF from AutoCAD:"The media name selected could not be found on the HDI Postscript printer PC3 file."
