Highlight and Select Text aren't working
The
Highlight and
Select Text tools select text you don't want.
If your highlights are opaque and conceal your drawing or text, see this article.
Cause
Text in a PDF is stored in individual lines instead of blocks or paragraphs. As a result, dragging the cursor downward to select multiple lines of text might select text on the other side of the page.
Here are a couple of alternative methods you can use to accurately select and highlight text. You may find each method to be helpful in different circumstances. If you're unable to select the text in your document, it may be an image of text rather than rendered text. Run OCR on your document to make the text selectable.
Click and drag
Holding down the Ctrl key while using the
Select Text tool releases its snap-to-text function, allowing you to draw a rectangle around the text you want to select.
- Go to Edit > PDF Content > Select Text (Shift+T) or click the
Select Text button in the Navigation Bar. - Hold down the Ctrl key, then click and drag to draw a rectangle around the text. The selected text will have a temporary blue highlight.
- Right-click the selected text and click Highlight Selected Text.
Draw a freehand highlight
You can manually activate the Highlight tool's freehand mode by holding down the Ctrl key. This disables the snap-to-text function, allowing you to draw a freehand markup over text (similar to the
Pen tool).
- Click Tools > Markup > Highlight (H).
- Hold down the Ctrl key and draw a line over the text you want to highlight. Draw a straight line by holding down the Ctrl and Shift keys.
Markup
