Hyperlinks don't work in Presentation view
Hyperlinks do not work when Revu is used in Presentation view.
Cause
This issue is caused by the fact that Presentation view displays an image of the file instead of the original PDF. Although this improves the speed of on-screen rendering, the image doesn't contain dynamic content, like hyperlinks.
If you need a full-screen view with working hyperlinks, you should make sure the page view is set to Fit Page (Ctrl+9) or One Full Page
, and then switch to Full Screen
mode by pressing the F11 key on your keyboard. To get out of Full Screen
mode, you can press F11 again or click the Full Screen
or Leave button in the floating toolbar.
Editing Documents
Hyperlinks do not work when Revu 20 is used in Presentation view.
