Images added to Revu for iPad appear blank
Support for Revu for iPad will reach End of Sale on December 31, 2025. For more information, see Bluebeam End of Life (EOL) Support.
When you add a picture to Revu for iPad from your Photo Library, your images appear blank or don't display correctly.
  1. Open the iPad Settings app.
  2. Go to Camera > Formats > Most Compatible
Any images taken with the iPad from this point forward can be attached without issue in the Revu app.
Cause
This issue is related to the image format used by Apple devices on iOS 11 and later. When the iPad's camera format is set to High Efficiency, photos are saved in the .heif format, which is not compatible with Revu. Images already captured in this format cannot be used in Revu without first converting them to a .jpg.
Revu for iPad
Markup
If when you add a picture to Revu for iPad from your Photo Library, your images appear blank or don't display correctly, this article describes how you can resolve the issue.
