Installed fonts don't appear
A font that's installed on your computer doesn't appear in Revu.
Causes
The font type isn't compatible with Revu
Revu supports TrueType (.ttf) and OpenType (.otf) fonts. These are the standard font formats used on Windows. Fonts in other formats are not supported.
The font file isn't saved to the correct location
Revu uses fonts that are saved to the following folder: %SystemRoot\%fonts. If a font doesn't appear in Revu, it may not be saved to the correct location.
Save the font file to the correct location
Try this solution after confirming the font type is TrueType or OpenType. You may need administrator privileges on your computer to complete these steps.
- Close Revu if it's open.
- Open the font file location in File Explorer.
- Right-click the file and select Install for all users.
- Open Revu.
The font should now appear in the Font Toolbar.
Compatibility
System & Environment
