Some features and tools that use JavaScript aren't functional
When using Revu 21, some tools and features that use JavaScript do not function as expected. Issues include, but are not limited to:
- You can't choose a custom status after saving it to your Revu Profile.
- You can't place interactive/dynamic stamps.
- You can't use the JavaScript tool under Tools > Forms.
- You can't see form fields in the PDF, and you can't type in them. However, you can see and interact with those form fields in other PDF viewers.
To solve this issue, download and install the latest update for Revu 21.
If you are having trouble using certain Revu 21 tools and features that use JavaScript, this article provides a solution to the issue.
