Measurement tools snap at 45 and 90 degree angles
When placing a measurement on your PDF, lines snap at orthogonal angles (45 and 90 degrees) as you move your cursor.
Cause
This issue occurs when the Snap Orthogonal option is enabled in the Measurements panel.
Follow the steps below to disable Snap Orthogonal.
- To open the Measurements panel, select Window > Panels > Measurements.
- At the top of the panel, select the Measurements dropdown.
- Toggle Snap Orthogonal to disable it.
If the issue persists, double-check your snap settings in Revu > Preferences > General > Grid & Snap.
If your cursor snaps at 45 and 90 degree angles, which limits you while placing measurements in Revu, here's how to fix it.
