PDFs print as blank pages and print preview is blank
When you send a PDF from Revu to a physical printer, the pages print out blank, and the print preview is also blank.
Cause
This tends to happen when the Dim Page Content option is selected in the Print dialog.
To deselect this option:
- Select File >
Print.
- Deselect Dim Page Content.
If this is unsuccessful, try the following steps:
- Select File >
Print.
- In the bottom left corner of the Print dialog, select Defaults > Restore Defaults.
Still experiencing issues? Contact Bluebeam Technical Support for additional help.
If your PDFs are printing as blank pages and the print preview in Revu is blank, learn more about a possible workaround here.
