Pen tool draws broken lines when using stylus and tablet
The Pen tool draws broken or rough lines when used with a Surface Pen.
Cause
The Pen Commitment Interval is not set correctly.
Set the correct Tablet Preferences in Revu.
- Go to Revu >
Preferences (Ctrl+K).
- In the Preferences sidebar, select Window.
- On the Tablet tab, set the Pen Commitment Interval between 300 and 600 ms.
- From the Touch Input dropdown menu, select All Functionality.
- Select OK.
Use the Pen tool again to verify the issue is resolved. If the problem persists, try adjusting the Pen Commitment Interval again.
Markup
