Tips for improving performance
Problems
Here is a list of issues that may indicate that your performance has degraded:
- Documents render and refresh slowly when zooming and navigating.
- Documents take longer than usual to open.
- Program becomes unresponsive.
- Interface is slow to respond to input.
Solutions
1. Change the rendering engine in Revu
Revu includes multiple rendering engine options. Hardware rendering generally works best, especially if you have a dedicated graphics card. To change the rendering engine, follow these steps:
- Go to Revu > Preferences.
- In the Preferences dialog, select Advanced.
- Select the 2D Rendering tab.
- From the Rendering Engine dropdown, select Hardware, and then select OK.
2. Change the Rendering Mode in Revu
The Wait for Completion rendering mode disables partial redrawing of the display. Instead, the screen will not update until the full page is ready to display, which reduces the total redraw time for the PDF, especially for 4k displays.
- From the Rendering Mode dropdown menu, select Wait for completion, and then select OK.
3. Change the power settings in Microsoft Windows
Aggressive power saving settings sacrifice display performance to reduce power consumption and extend battery life. They affect both laptops and desktops. See Microsoft's documentation to change the power mode for your PC.
4. Update the Microsoft Visual C++ Redistributable:
Install the latest version of the Microsoft Visual C++ Redistributable. These updates will improve rendering performance for large images and scans within Revu.
5. Update the Microsoft .NET Framework
Install the latest Microsoft .NET Framework that your PC can work with. Click here to find which Windows version you're running, and then check this page to find the latest version of .NET that your version of Windows supports.
Once the .NET installation is complete, documents will open faster and the general performance and responsiveness of the program will improve.
Contact Technical Support
If none of the steps above improve your performance, please contact the Support team so we can help identify the problem. You'll get the fastest resolution by opening Revu and going to Help > Send Log Files, which attaches the Revu log files and settings to a new email message.
Please include a detailed description about the issue you're having, attach relevant sample files, and answer the questions below. This will help us identify the cause more quickly.
- How much RAM does this computer have?
- Are you accessing the files locally or across a network?
- Do you have multiple monitors?
- Are you using a high resolution monitor, such as a 4K display?
