Recover Unsaved Changes dialog isn't responding
You encounter the Recover Unsaved Changes pop-up window upon opening Revu.
"Recover Unsaved Changes" dialog shows lost files with options to recover or remove; user can select files, click OK or Later.
Revu either freezes when you try to recover or remove a file, or the notice appears accompanied by the same files every time you launch the program. This occurs even if you recovered/removed those files in a previous instance of Revu.
Cause
When this happens, there's usually a file in the Recovery folder causing an issue in the backend of the program.
To restore proper functionality to the Recover Unsaved Changes dialog box, you'll need to clear the cache of recovery files on your local drive.
  1. Close Revu.
  2. Copy and paste the following relative path in the File Explorer search bar:
    %localappdata%\Bluebeam\Revu\20\Recovery
  3. Delete all content inside the Recovery folder.
  4. Relaunch Revu.
The Recover Unsaved Changes pop-up window should no longer freeze or appear upon opening the program.
PDF Management
Drawing Management
Editing Documents
Find out why Recover Unsaved Changes isn't functioning properly and how to fix it.
