Trial expired when using Bluebeam plugins
Revu is registered, but a message displays saying the trial is expired when you attempt to use the AutoCAD, Navisworks, Revit, SolidWorks, or SketchUp Pro plugin. If you attempt to register, a message displays reporting the serial number and product key cannot be validated.
Cause
For Revu 20 users, this message displays when you try to use one of the Bluebeam CAD plugins with Revu Standard. A license for the CAD plugins (AutoCAD, Revit, Navisworks, SolidWorks and SketchUp Pro) is only included with the CAD and eXtreme editions of Revu. With Revu Standard, these CAD plugins can be enabled and used in trial mode for 30 days. Once this trial expires, you must upgrade to Revu 21 with a Core, Complete, or Max plan.
You can still create 2D PDFs from your CAD application by printing to the Bluebeam PDF Printer.
To find the Bluebeam plan, edition, or serial number for your installed product, follow these steps:
- Open Revu.
- Select Revu > About.
Integrations & Plugins
