Unable to delete tool set
You're unable to delete a tool set because the Delete button is grayed out in the Manage Tool Sets window.
Cause
When you configure a tool set to be visible in all profiles, Revu includes the tool set in each profile. This grays out the delete button to prevent you from accidentally removing a tool set that's used in another profile.
All newly created tool sets are configured to be visible in all profiles.
You can delete a tool set once you've cleared the Show in All Profiles check box in the Modify Tool Sets window. To do this:
- In the
Tool Chest panel, select the Tool Chest dropdown, and click Manage Tool Sets.
- Right-click the tool set and select
Edit.
- Clear the Show in All Profiles box and select OK.
Delete.
Deleting a tool set removes it from Revu, but doesn't delete the corresponding .btx file from its saved location on your device.
Interface & Navigation
You're unable to delete a Tool Set because the Delete button is grayed out in the Manage Tool Sets window.
