Work offline in Studio
You can work with Studio Projects and Sessions files in Revu without an internet connection. Designate the files you need to access while offline, and any edits you make will automatically synced to your Projects or Sessions when you reconnect.
Studio Projects
Prepare to work offline
- Open the
Studio panel, and open your Studio Projects.
- To designate the files you want to work with, hover over a file or folder and select
Set to Sync on the right. The icon will become
solid green to indicate the file or folder is ready to sync. Files that haven't been marked as set to sync are not available when you work offline.
If a folder is set to sync, all subfolders and files within it will sync as well. - Right-click the top-level Projects name in the Project tab, and select
Sync to create locally cached copies of the files. The folder is in the Project tab with an
Invite icon to the right.
- To check out the files you'll need while working offline, right-click the file, and select
Check Out.
Checking out the files prevents others from making changes to them. When you check out a file, it's added to the Pending section at the bottom of the Studio panel. - To begin working offline, select
Connected at the top of the Studio panel.
- In the confirmation dialog, select OK.
Upload your changes when you are back online
While working offline, edit and save the document as you normally would.
When you reconnect to the internet, you can sync your files to the Studio Projects.
- Select
Offline at the top of the Studio panel.
- Right-click the documents in the Pending list, and select
Check In.
- Add any revision comments, and select Check In.
To learn more about Studio Projects and Studio offline, see the Revu Help Guide.
Studio Sessions
Open files before going offline
When you upload files to a Studio Sessions, Revu stores them in the cloud. To open the most recent version of a Sessions file, you need an internet connection. Before going offline, connect to a Studio Sessions and open the files you plan to work with offline. The files are automatically downloaded and cached in the Sessions, which ensures that you have the most recent versions of your documents.
Work offline
After opening your files, you can go offline and work as you normally would. Any markups you make to your Sessions document are preserved and automatically synced with the Sessions once you reconnect to the internet.
Markups made while offline display a
Pending Upload icon and are listed in the Pending tab at the bottom of the Studio panel.
To learn more about working with Studio Projects and Studio Sessions offline, see the Revu Help Guide.
