Pen tool
The Pen tool is used for free form text, shapes, or other unique markups.
- Select the Pen tool using one of the following methods:
- Go to Tools > Markup >
Pen. - Select
on the Text toolbar. - Press P on the keyboard.
- Drag to place a free form line (simulating a pen or pencil) on the PDF.
- Release to end the line.
Tips for using the Pen tool:
- Hold down SHIFT to draw straight horizontal or vertical lines.
- Any number of pen lines created at the same time are considered to be the same markup and will appear as one entry in the Markups List. Revu creates the markup after a delay of about a second. To prompt it to create the markup without waiting, press ENTER after drawing a line.
Delete.
The appearance of the pen line is configurable, including its color, thickness, and opacity. Pen lines can also act as highlights, becoming fully transparent to let underlying content show through.
To change the appearance of a Pen markup, select the markup and select the Properties panel. Go to Window > Panels > Properties to show the Properties panel if it is hidden. Several properties will also be available on the Properties toolbar when the markup is selected.
Color: Sets the color of the pen line.
Opacity: Sets the opacity level of the pen line as a percent, where 100% is completely opaque and 0% is completely transparent.
Line Width: Sets the thickness (in points) of the pen line.
Highlight: When enabled, makes the pen line appear completely transparent so that the underlying PDF content shows through without affecting its opacity.
