3-Point Radius measurement
The 3-Point Radius measurement tool lets you create a markup that measures the radius of an arc. The tool always starts with an arc, but you can resize it to form a full circle after placement. If you need to create a circular markup that calculates the radius immediately, use the Center Radius Measurement tool instead.
Before you start, set the page scale for your document first. If you try to place a measurement on a page without a scale, you'll be prompted to set one.
- Go to Tools > Measure >
3-Point Radius. Or, select
3-Point Radius on the Measurements panel. -
To change the units for any dimension, select the desired measurement units from the dropdowns in the Measurement Properties section of the Measurements panel. Measurements can be taken in units different from those used to set the page scale. Any or all of these can also be set from the Units dropdown menu on the Properties toolbar.
Changes you make to properties will apply to all new measurements until you switch tools (for example, when you place a different type of measurement). - In the document, click to set the first end of the arc.
- Click a point along the arc that is not at either end.
- Click to define the other end of the arc.
Revu draws a pie-piece shape and displays the measured radius.
When you've set the page scale, a preview of key measurement values appears in the lower-right corner as you place measurements to ensure precision. Hide or recall it as needed by selecting the X or the measure icon.
- Revu prevents this tool from placing a full circle. To create a circle, resize the Three-Point Radius markup or use the Center Radius Measurement tool.
- Hold Ctrl and drag an existing markup to automatically copy it.
- Change properties (Subject, Label, units, Slope, Depth) after placing the measurement by selecting it and using the Measurements panel.
Delete.
Rotate the caption: Drag the orange handle directly over the caption.
Change the size of the arc: Drag one of the yellow handles on the markup's circumference.
- Hold Shift to adjust in 15° increments.
Change the length of the radius: Drag the yellow handle at the circle's center.
Move the entire markup: Drag any part except the control handles.
You can customize the appearance of the radius measurement, such as line and fill color, pattern, line style and width, opacity, and font settings for the caption.
To change the appearance of a Radius measurement, select the markup and select the Properties panel. Go to Window > Panels > Properties to show the Properties panel if it is hidden.
Color: Sets the line color.
Style: Determines the line pattern.
Show Caption: Display caption text. Select Edit to choose which measurements to show.
Show Centroid: Display the geometric center. If necessary, the caption will be automatically adjusted to be below the centroid.
Font Style: Control the formatting of the text. Options include Bold, Italic, Underline, and Strikethrough. Generally, any combination of these styles can be applied to format the text.
