Ellipse tool
The Ellipse tool places an ellipse markup on the document. Holding down the Shift key will cause the ellipse markup to automatically form a circle. The use of the Ellipse tool is nearly identical to that of the Rectangle tool.
- Select the Ellipse tool using one of the following methods:
- Go to Tools > Markup >
Ellipse. - Select
on the Shapes toolbar. - Press E on the keyboard.
- Drag to define the size of the ellipse.
- Alternatively, select two points to define the opposite corners of the shape.
- To define a circle by its radius, hold down ALT and drag along the desired radius.
Tips:
- Hold down Shift while defining the shape to force the shape into a circle.
Delete.
- Use the side control handles (yellow squares) to stretch or compress the markup in a single direction.
- Use the corner control handles (yellow circles) to scale the markup up or down in multiple directions.
- Hold down Shift while dragging a corner control handle to force the shape into a circle.
The appearance of the Ellipse markup is configurable, including its line and fill color, hatch pattern, line width and style, and opacity.
To change the appearance of an Ellipse markup, select the markup and select the Properties panel. Go to Window > Panels > Properties to show the Properties panel if it is hidden. Several properties will also be available on the Properties toolbar when the markup is selected.
Color: Sets the line color.
Style: Determines the line pattern.
In addition to the standard line styles, there are several advanced styles and you can create Custom Line Styles, if desired.
