Automate calculations with form fields in Revu
In Revu, you can use Form Fields to automatically calculate values entered into a PDF form, similar to Microsoft Excel. You can calculate everything from salaries to prices for building materials.
To get started, you’ll need to create at least three text boxes. Any number of text boxes may contain values to be calculated, while at least one of the text boxes will display the result of the calculation.
Create and enter values in text boxes
- Open the
Forms panel: Window > Panels > Forms (Alt+Q)
- Go to Tools >
Reuse. This allows you to place the same markup as many times as you need to. If active, the text will be highlighted in blue. Select it again to turn it off.
- Select the
Text Box tool. Your cursor turns into a crosshair over the workspace.
- Drag to designate the size of your text box. Continue creating text boxes until you have at least three.
- Once the text boxes are placed, press Esc two times. The control points disappear.
- Select the text boxes to enter numeric values. Leave at least one box empty; this will be your output box.
Change your values’ categories
- Select a text box from the
Forms panel.
- Open the
Properties panel (Alt+P).
- Open the Format section.
- From the Category: dropdown list, select the appropriate value.
Set up the output box
- Open the
Forms (Alt+Q) panel.
- By default, your text boxes will be named “TextX.” X represents a number determined by the order the text boxes were placed in. Double-click on the entries here to rename them. Keep in mind that text boxes with the same name will synchronize their changes (i.e. whatever is changed in one is also changed in the other).
- Select the text box in the
Forms panel that you want to display the calculation output.
- Open the
Properties (Alt+P) panel for this text box.
- Scroll down to the bottom of the
Properties panel, and open the Calculate section (if it’s minimized).
- Select a Calculate Property from the dropdown list based on the type of calculation you would like to perform:
- Value is not calculated – The default option. Calculation results will not be displayed in the text field. In most cases, every text box except your output box should be set to this property.
- Calculation field – Displays either a sum, product, average, minimum, or maximum of specific values in the selected text box. To specify which values are calculated, select Select, then select the box that you would like to calculate with from the next dialog box.
- Simplified field notation – Displays the result of any combination of addition (+), subtraction (–), multiplication (*) and division (/). Parentheses ( ) may be used in any combination as well. Select Edit to enter your equation.
Revu can calculate somewhat complex combinations of parentheses, such as: ( ( (Text1+1+1)+2 ) * (Text2+4) ) / 5
You can enter both numbers and text field names in your calculation. If a text field name is entered, Revu pulls the value entered in that text box and uses it in the calculation.
Copy names from theForms(Alt+Q) panel when writing the text box names.
- Custom Calculation Field – Select Edit, and the JavaScript Editor window will open. Enter your custom JavaScript in the field. Select Global scripts to select or edit a Global script you already made, or create a new one.
For more examples of form calculation fields, see the Revu Help Guide.
Once you select a calculation option, the result displays in your calculation output field.
Revu Standard
