Enable Bluebeam plugins
Before you activate a plugin, confirm that your version of Revu is compatible with the version of the application you'd like to integrate. Click here for our compatibility chart.
If you've installed Bluebeam Revu and would like to enable plugins with another application (AutoCAD, Microsoft Office, etc.), you must enable them in the Bluebeam Administrator. Currently, Bluebeam offers plugins for the following programs:
  • AutoCAD and verticals built on top of AutoCAD, such as Architecture and Mechanical
  • AutoCAD LT (AutoCAD LT doesn't utilize all features of the Bluebeam plugin. You won't have access to any of the batch options available in AutoCAD.)
  • Autodesk Revit
  • Autodesk Navisworks Manage and Navisworks Simulate
  • SolidWorks
  • Microsoft Office (Word, Excel, and PowerPoint)
This feature is only available with a Core, Complete, or Max plan.
Enable plugins in the Bluebeam Administrator
  1. Open Revu, and sign in when prompted or select Sign In.
  2. Select Revu > Administrator.
  3. On the Plugins tab, select the integrations you want to enable.
  4. Select OK to activate the plugin.
    If the third-party application is open, close and reopen it. The Bluebeam toolbar/menu/ribbon should appear now.
To reset a plugin, deselect the application in the Bluebeam Administrator and apply the changes. Then, reselect the application and select OK.
Activate a Bluebeam plugin within Microsoft Office 10 and above
  1. Open the Microsoft Office program you want to integrate with Bluebeam Revu.
  2. Select File > Options.
  3. Select Add-ins in the left sidebar.
  4. At the bottom of the dialog, select COM Add-ins from the Manage dropdown list.
  5. Select Go.
  6. Select BluebeamOfficeAddIn.
  7. Select OK.
Activate plugins when deploying Revu
If you're an IT professional installing Revu for multiple users, see the Bluebeam Revu Deployment Guide for more information about activating plugins in bulk. Additionally, if your organization would like to utilize our SharePoint integration, click here for more information about requirements and setup.
