Export, import, and manage Profiles
Profiles provide an easy way to store your favorite toolbars, menus, and other display settings within Revu. Like tool sets, you can export your custom profiles and then add or import them to another Revu account.
In addition to profiles, you can customize tool sets and stamps within Revu to best suit your needs.
Exporting a profile
To export a profile, perform the following steps:
- Go to Revu >
Profiles >
Manage Profiles , or select the Profiles icon
in the Navigation Bar.
If you don't see the Navigation bar, go to Tools > Toolbars > Navigation Bar (F4) to show the toolbar in your workspace. If the Profiles icon isn't visible in the Navigation Bar, you'll need to access the Customize Toolbars tool. - Choose the profile that you'd like to share, then select Export. The profile will be saved as a .bpx file that can be emailed or uploaded to a shared network drive or any other file sharing system.
- If you select Include Dependencies before exporting, then Revu will include tool sets, Bookmark Structures (Revu eXtreme or Revu 21 with a Complete or Max plan only), hatch patterns, and line styles in the exported Profile. Upon importing the profile back to Revu, these dependencies will be included as well. Select OK.
Importing a profile
To import a profile to Revu, perform the following steps:
- Go to Revu >
Profiles >
- Select Import to copy the .bpx file to the file path found in the Location field. You can go to this designated folder to remove or copy profiles as needed.
- Select OK.
Manage your profiles
You can create a new profile, which you can then customize. You can also rename or delete existing profiles.
To add a profile, perform the following steps:
- Go to Revu >
Profiles >
- Click the Modify button and enter the new name for that profile.
- Click OK.
To rename a profile, perform the following steps:
- Go to Revu >
Profiles >
- Select the profile you want to rename.
- Select Modify, and enter the new name for that profile.
- Select OK.
To delete a profile, perform the following steps:
- Go to Revu >
Profiles >
- Select the profile you want to delete.
- Select Delete.
- Select Yes.
Markup
Interface & Navigation
Profiles provide an easy way to store your favorite toolbars, menus and other display settings within Revu.
