Share Stamps
Stamps are meant to mimic traditional rubber stamps placed on paper documents. They are static after being placed on a PDF, and can't be edited after they are placed. Stamps can be emailed, stored on a network, or sent to other users like any other file.
Importing Stamps
To add a Stamp to the local Stamps folder:
  • Go to Tools > Stamp > Import Stamp.
To use a Stamp located on a shared network location:
  • Go to Tools > Stamp > Change Stamp Folder.
Exporting Stamps
To export a stamp, go to the Stamps folder in Windows File Explorer. From there, you can email or upload the desired PDF to a shared network drive, or another file sharing system.
By default, your stamps are stored in one of the following locations, depending on your version of Revu:
Revu 21.10 and later:
%AppData%\Bluebeam Software\Revu\21\Stamps
This resolves to:
C:\Users\<Username>\AppData\Roaming\Bluebeam Software\Revu\21\Stamps
If the AppData folder isn't visible, you'll need to unhide it. In your <Username> folder, select View > Show > Hidden items.
Revu 21 versions before 21.10 and Revu 20:
C:\ProgramData\Bluebeam Software\Bluebeam Revu\<Version Number>\Stamps
Learn More
In addition to stamps, you can customize profiles and tool sets within Revu to best suit your needs.
Markup
Interface & Navigation
