Make Revu your default PDF viewer
Windows 11
Follow the steps below to set Revu as the default PDF viewer.
You must run Revu as an Administrator in order to perform this procedure.
- Open Revu.
- Go to Revu > Preferences.
- Select Admin from the left-hand menu.
- Under Default PDF viewer, select Open Default Programs.
- In the Default Apps window, select Bluebeam Revu under Set defaults for applications.
- Select the program currently assigned to .pdf, and then select Revu.
Setting Revu as the default viewer also enables Bluebeam as the previewer in Windows Explorer.
Windows 10
Microsoft ended support for Windows 10, Office (2016-2019), and Outlook (2016-2019) on October 14, 2025. For optimal performance and compatibility, we recommend upgrading to the latest Microsoft products.
Follow the steps below to set the Revu as the default PDF viewer.
- Open Revu.
- Select Open Default Programs.
- When the Default Apps window displays, complete these additional steps:
- Scroll down and select Choose default apps by file type.
- Scroll through the list until you reach .pdf, then select the plus icon or the program currently associated with .pdf.
- Select Bluebeam Revu from the list of programs.
To automatically launch Bluebeam when opening PDFs from the web, see Open a browser PDF directly in Revu.
How To
Learn about how to set a default printer in Revu.
