Prepare your documents for Smart Overlay and Smart Review
Smart Overlay and Smart Review work best when your PDFs are organized and optimized before you start. Follow these guidelines to help ensure smooth processing and accurate results.
Use PDF files only
Smart Overlay and Smart Review work with PDFs exclusively. Convert your documents to PDF format before uploading.
Stay within size limits
Keep your total file size under 1.75 GB. This applies to both Version 1 and Version 2 in Smart Overlay, or the drawing set you're analyzing in Smart Review.
Manage page count
For Smart Review, limit your combined PDFs to 2,000 pages. For Smart Overlay, limit both versions of your PDFs to 2,000 pages for a combined total of 4,000 pages. If you're working with larger sets, split them into smaller batches and run separate analyses.
Match title blocks consistently
Smart Overlay uses title blocks to identify and match sheets between versions; Smart Review uses title blocks to compare to the index. For accurate matching, make sure of the following:
- Each sheet number is unique within its set.
- Sheet numbers are consistent across the versions you're comparing.
- Title blocks are clearly visible and not covered by markups or annotations.
Keep scales consistent
When comparing drawings with Smart Overlay, use documents at the same scale. Differences in scale or alignment will appear as changes in the comparison.
Use floor plans for Smart Review
Smart Review currently works best for floor plans. You'll get the most accurate results with the following types of files:
- Floor plans showing walls, doors, and windows
- Documents using standard architectural conventions
- Drawings that include gridlines, schedules, and sheet indexes
Civil drawings, site plans, and documents other than floor plans may produce less consistent results.
Flatten or remove markups before comparing versions
If you're using Smart Overlay to compare drawing versions, keep in mind that markups in one version will appear as differences. If you want to compare the base drawings only, flatten or remove markups before uploading.
Use unrestricted PDFs
Make sure that your PDFs are unrestricted and without password protection to allow Smart Review to work properly.
