Installation Error 1303: "Insufficient privileges to access this directory"
When upgrading Revu, the following error displays and the installation stops.
Error 1303. Insufficient privileges to access this directory: C:\Program Files\Bluebeam Software\Bluebeam Revu. The installation cannot continue. Log in as an administrator or contact your system administrator.
If this error displays when reinstalling or upgrading Revu, follow these steps to successfully complete the installation.
- Restart the computer and start the Revu installation again. The permissions of the folder mentioned in the original error should be resolved after Windows restarts. The installation should now complete successfully.
- If the problem continues, restart your computer in "safe mode".
- Open the folder Program Files folder:
- Select Start, type C:\Program Files and select enter.
- Delete the Bluebeam Software folder.
- Restart Windows normally and login using your regular Windows account.
- Restart the Bluebeam install.
Contact the Support team if you continue to have permissions problems with the installation.
Error Message
