Scale or unit of measurement is incorrect for custom measurements
The measurements you create are using an incorrect scale or measurement unit.
Cause
The document contains at least one viewport that defines the scale and units of measurement.
To remove the unwanted viewport, follow these steps:
- Open the
Measurements (Alt+U) panel and expand the Viewports section.
- From the Viewports list, select the viewport to delete.
- Select
Clear All Viewports.
- Do one of the following:
- Select Clear All From Page to delete the highlighted viewport from the current page
- Select Clear All From Document to remove viewports from the entire document.
Measurement
This article explains why your drawings turn blue while taking measurements and the scale can't be set properly, and how to fix these issues.
