Install the latest Bluebeam plugin for your CAD software
You don't see the Bluebeam plugin in your AutoCAD, Revit, Navisworks, SketchUp Pro (Revu 20 only), or SolidWorks installations.
The plugins for AutoCAD, Revit, Navisworks and SolidWorks are included in the following:
Revu 21: Bluebeam Core, Complete, or Max plans
Revu 20: Revu CAD and eXtreme
To activate the CAD plugin, first check the Compatibility Chart to see if your version of Revu supports the installed version of your CAD software. Once confirmed, follow these steps:
- Close your CAD software, if it is running.
- In Revu, Go to Revu > Administrator.
- On the Plugins tab, select your software and select OK.
- Restart AutoCAD.
If AutoCAD is already selected, follow these steps:
- Open the Bluebeam Administrator.
- Clear the check box and select Apply. Don't close the Administrator.
- Open AutoCAD. Once it opens, close it immediately.
- Return to the Bluebeam Administrator.
- Select AutoCAD, and select OK.
- Restart AutoCAD and close Bluebeam Administrator.
Setup
Integrations & Plugins
