Pages are rotated or skewed after running OCR
After running OCR on a PDF in Revu, some or all pages are rotated or skewed.
Cause
This happens when the Correct Skew option is enabled in the OCR dialog. If the PDF contains text at an angle, the OCR function will rotate pages or the whole document to correct it.
To fix this issue, disable Correct Skew before running OCR.
- Select Document >
OCR.
- In the OCR dialog, deselect Correct Skew.
- Select OK.
Still experiencing issues? Contact Bluebeam Technical Support.
After running OCR on your PDF, pages are rotated or skewed. Here's how to troubleshoot the issue, so pages are the correct orientation.
