TrueType text is clipped at the edge of a sheet or viewport
TrueType fonts are clipped at edge of a sheet or viewport, usually the bottom and left sides, when the PDF is created using the Bluebeam printer driver in AutoCAD.
You can resolve the problem using any of the following options.
- Use Post Processing when creating a PDF:
- In the Save As window, select the Enable option under Post Processing.
- Select Manage.
- Select the Remove Text Clipping option and click OK.
- Use Repair Page Content on a PDF that has already been created:
- Open the PDF in Revu.
- Select Document > Repair PDF.
- In AutoCAD, change the margins that are defined in the page size. AutoCAD places a default margin of 1/8" on all four sides of the drawings.
- Change the margins to 0 inch (or 0mm) for all four borders.
- For details about changing the printable page size, click here.
- Change the plugin to use the Heidi driver. The Heidi driver converts TrueType text as geometry and the clipping does not occur. To use the Heidi driver:
- Exit AutoCAD.
- In Revu, select Revu >
Administrator.
- Select the AutoCAD Page Sizes tab.
- Select Heidi or Printer Driver in the dropdown list.
- Click OK to exit the Administrator.
- Restart AutoCAD.
TrueType text will not be searchable in the PDF when the Heidi driver is used because the TrueType fonts in the drawing will be exported as vector line segments and not searchable text. To find out more information about the different types elements in a PDF file, click here.
Editing Documents
TrueType fonts are clipped at edge of a sheet or viewport – usually the bottom and left sides – when the PDF is created using the Bluebeam printer driver in AutoCAD.
